HI, im trying to downgrade my 3060 to the 460.39 driver.
1st -is it still working?
2nd- I get invalid driver selection what am i doing wrong thanks
Just put in the number and not “nvidia-driver-update” as a prefix.
Enter the version to install: 460.39
LHR v2 ? Thanks
do you have any oc for my 3060 v2. i cant get even 110mhz for ergo. my driver is 460.91.03
Hi guys, I am new to this hole crypto mining world, still discovering a lot of things.
I have 3 RTX 3060 LHR V2 Colorful boards, that are around 103 MH with the following settings:
Core: 1580 Memory: 0 Fan: 65 PL: Not configured
All 3 have around 103 MH, is it possible to get a better result with different configuration for this board model?
One of the board is not accepting the FAN configuration, so it keeps changing during the day between 30 and 100%, and this board is gettibg really hot, around 67 to 70º C. Any idea on how to fix this issue?
I’m new to mining and HiveOS too.
Did find OC settings on another post. Getting arround 113 MH/s with the following settings. Been stable for the last 24hr:
thank you so so much. i set your settings and i get 110mh. it happened 10 min ago. but i tried different settings after that. everytinh is same only core -360 or -370. and i got 116mh. can you try, let me know?
dude dont use -360 or -370 lol. try -330.
Thanks to you now. Seems to go a bit higher at -330:
Got a GPU Temp error last night with my previous settings but mining did restart at I got pretty good result.
Let me know if your configuration is stable.
Tx
i set -300 and i got 119mh for 2 hours. but it wasnt stable. and right now i set -310 and last 2 hours it is stable. i will let you know for the best at least for me.
What miner are you using?
I’m using NBminer 39.2.
Did run at -310 all night with errors every hour or so.
I’m running at -320 now to test. -330 was stable.
@chbmaciel , are you stable at -300 ?
I had 2 reject shares in 9 hours.
At -300, I’m having errors of “GPU drivers, no temps”, and “Load Average > 22” every 1 or 2 hours.
my most efficient setting and stable for days is this:
GPU #1: NVIDIA RTX 3060 - 106.29 MH/s, [T:57C, P: 87W, F:95%, E:1.22MH/W], 1946/1948 R:0.1%
core 1250
memory 2530
power 101
fan 95%
nvidia driver 470.63.01
I have a rig with one 3060 (LHR ofc). I’m mining Ergo, on stock settings 102.8 mh/s @ 100w. As soon as i change Core or memory the hashrate drops to 50/60. What can i do, i have tried everything in this tread. I have driver 465.31.
i tried 460.39, but it doesn’t work. i’m using 2miners/NBminer 39.2
what to do?
Brand new to this with first rig but managed to weasel this out of my 3060 Zotac on 460.91.03
Curious if there are better to tweaks to get more out of this LHR card.
Try this settings:
Core: -300 or -310
Mem: 2700
PL: 100
