Im trying to built rig with 6 rtx 2060 gpus but when i plug in 4 and 5 gpu i gettu 106 rev A and card info is not displayed… Anyone who have came across same problem please help…
What is your hashrate on hynix memory 2060?
31mh/s
Can you give me your oc settings?
When you switch GPU’s (with only using 3) do you still have the same problem?
I has this problem with the Asus 2060. It was connected via a x1 riser. I solved it in the BIOS of the motherboard. I changed the PCIe setting for that x1 PCIe slot to gen 2. Then it was recognized properly.
Some motherboards may not allow you to set a different setting for each slot. I think the guideline from HIVEOS is to update to the latest BIOS and set all PCIe slots to gen 2.
hello i have the same problem i have an asus tuf gaming motherboard gen 2 don’t do it how can i fix it can you help me
[image]
