hello, i had 2gpu’s only, rx 5500xt and rtx 2060.
i use one pcie multiplier 1 to 3, cause i had a old motherboard…
if I connect the 2060 on the pcie multiplier she doesnt work, if I connect in mobo, she works.
the rx 5000 xt, works fine, in mobo or pcie multiplier.
If I connect rx5500 and rtx2060 on multiplier, only rx works
someone can help?
sorry bad english
Are you using 1 pcie cable per card? Or do you run multiple cards per cable?
