hi, I am new to GPU mining. Can anyone lead me a way to set RTX 2060 overclock setting.
Hi, I can help you.
First, you set core 1050 and mem 2000. You have to work within 72h or more. After that you can adjust a little mem 2200 and still run 2 days.
Next, you will set core 1100 and mem 2400. This setting will work about 7 days.
Second, you set max with core 1100 and mem 2700. You get 32 - 32.5 mh/card
Good luck!
Hi, alright i will try it.
Thanks a lot
Hi! you’re welcome!
Hi!
First, reboot your rig. Second setting core 1100 and mem 2000, P/L 125. Let it runs within 7 or 10 days. After that increasing a little mem 50 or 100 (2050 or 2100). after working 3 weeks, you can set mem maximum (2500 or 2700).
alright. Thank you so much
You’re welcome!
why do you need to wait a few days before the changes? sorry complete noob here
the gpu’s need a few moments to stabilize when you will change overclocking after 5 seconds you will not see a things that can happend like i don’t know randomly card is going to sleep or low mining speed and you need few days to check if they are ok
This has been my OC for almost a year now, I’m trying the third one with 2320 MEM because it’s been giving me ~2 invalid shares per day.
