Rig Won't Stop Crashing! - Help Appreciated
My rig was running nice and smooth for weeks without issue but after making a few additions I can’t get it to stop rebooting every few hours. I’m going to list out my set-up details when everything was running smoothly, the changes I made, the set up of my rig currently and the solutions I’ve tried. Any input would be greatly appreciated here. Thanks!
Previous (Stable) Rig Set-Up
Hardware:
XFX 6800 XT (2 cards)
  • Running the 113-5N21XT_200801 bios that it came with
  • Memory Clock – 1075
  • Core Clock – 600
  • Hash rate – 62.90 mh/s (each)
XFX 6900 XT (1 card)
  • Running the 113-69XB6SSB1-C02 bios that it came with
  • Memory Clock – 1050
  • Core Clock – 550
  • Hash rate – 61.40 mh/s
Biostar TB360-BTC Pro 2.0 Ver. 6 MOBO
Celeron G4930 CPU
EVGA Supernova P3 Platinum 1200
SanDisk Plus 240GB
Operating System:
HiveOS 0.6-208 @ 210818
Mining Software:
Team Red Miner (current version at time of)
Changes Made
  • Added 1 XFX 6800 XT card with the bios 113-5N21XT_200801
  • Added 1 XFX 6800 XT card with the bios 113-68XB6SSE1-C01
    • (Can anyone tell me why it came with a different bios out of the box?)
  • Swapped out previous EVGA P2 1200 PSU for 2 EVGA P3 1200 PSUs
  • Applied the same OC settings I had for the original 6800 XTs to the two new 6800 XTs
Current (Unstable) Rig Set-Up
Hardware:
XFX 6800 XT (3 cards)
  • Core Clock – 600
XFX 6800 XT (1 card)
  • Running the 113-68XBSSE1-C01 bios that it came with
  • Core Clock – 600
  • Hash rate – 62.40 mh/s
  • Core Clock – 550
Stock settings
Celeron G4930 CPU
EVGA Supernova P3 Platinum 1200 (2 PSUs)
SanDisk Plus 240GB
Operating System:
Mining Software:
Team Red Miner (0.8.6)
Solutions I’ve Tried
  • Updating HiveOS to the newest beta
    • This seemed to make it worse, so I reverted to 0.6-208 @ 320818
  • Flashing the 6800 XT 113-5N21XT_200801 bios from my 3 better performing cards to the card that came with the different bios
    • This caused HiveOS to not recognize that GPU when I rebooted so I flashed it back to its stock bios
  • Switched the HiveOS watchdog to only “reboot if gpu is offline”
    • Not sure if this has made anything better or worse
Anyone see any glaring issues here that could be causing this or is having similar issues themselves? Any input is appreciated, thanks mining fam!
Try reducing your overclocks significantly till it stabilislzes then increase by 5 every few minutes till it crashes, then decrease by 5 and let it go.
