I bought some new 3060ti s for a reasonable price. Now the issue is that the rigs won’t boot up if there are more than 3 zotac cards. I can change them all and it appears to really be the problem with this vendor as all other combinations work quite well. Did anyone got the same experience? Is that a new lhr limitation?
PSU Size?
1800w
should be sweet as.
take all cards out and put one card in at a time and make sure each one mines the same.
Then add one in at a time and see what happens.
the one that does not work when you add it in… shut down and put it into the slot that was working. confirm ok.
Then try changing the riser card in the one that does not register and then the PCIE BOARD (UNLIKELY) AND THEN THE cable.
I already confirmed all cards are working and all risers are working too, it should be the power but I don’t know how to properly connect 2 PSUs to an btc s37 mb as the pcie power lanes are all connected.
