Rig not connecting unless screen is connected
Hi
I have weird issue that unless my screen is plugged in my miner will not work. I can’t see it on HIVE OS and when i plug a screen in i get nothing. If i reboot system and have screen plugged in from the start all is well.
Any ideas, Thanks.
The same… For that, you can use hdmi plug in your motherboard that simulate a screen.
Cheers
Hey @Paulo, I seen these dongles, I’ll have to get one. Thanks.
Hey, I have the same problem, did you find a solution?
(Except of buying a dummy plug for OS that shouldn’t need it)
