my rig keep going offline , after so many troubleshooting i found the issue i have 5 cards : 3060ti lhr , 2x1070 , rx 580 and rx 570
i found out that whenever the 580 and 570 run together the miner won’t start and the rig goes offline i tried changing to the stock bios for both cards , i ran with no OC but same issue
i noticed that whenever i switch between the 580 and 570 hiveos run the 580 oc on the 570 or the other way around , it s like hiveos consider both cards like the same gpu and i think that s what causing the issue
