Hi
My rig going offline on dashboard but actually continue mining
I can’t monitor the GPU data
Does someone know how to fix it?
Clear cache and cookies at browser…
Go into your miner settings (in hiveos), under the “mirror select” section, change the api to the http://api.hiveos.farm. If that doesn’t work, you can also try pinging some of the other servers and change it to the one with the lowest ping. I was getting a ton of false offline errors on one of my rigs and it turned out the api was helsinki.hiveos.farm for some reason. I still get an occasional false offline message on telegram, but it’s now once every few days as opposed to every 15 minutes.
