So this one is weird. I switched to ethMiner recently, and noticed odd rig behavior - ‘something’ is restarting every ~45 minutes. I can’t tell if the rig is actually rebooting or just the miner for sure, but the only logs I can find show the miner losing connectivity to the pool and then terminating so I suspect it is just the miner. Occasionally it takes too long to restart and the watchdog bounces the rig. This is obviously a problem, it is cutting my effective hashrate by around 20%.
I’ve done quite a bit of troubleshooting - reverted clocks to stock, replaced all the risers, added external cooling, changed mining pools, etc etc. Out of desperation, I opened teleconsole and attempted to capture a miner log while it was rebooting… and it never rebooted. I’ve been able to duplicate this behavior several times now; if I keep teleconsole open, the restart doesn’t happen until the teleconsole session times out (~12 hours).
Does anyone have any clue?
