I switched to the beta and it seems that the restart problem has been solved. Thanks for your help! But today all the ASIC miners in the farm have gone offline ( 5 hours ago) in ASIC Hub when they are working fine. Can you please give me some advice?
Try rebooting your computer thats running asic hub
I have already tried that without success.Any other thing I can try?
Can you connect to the devices local dashboards?
Yes, I was able to connect to the devices local dashboards when the problem happened. Anyway, tonight the ASIC miners have appeared again as connected.
