FinMiner linux
https://miner.finom.io/?utm_source=mail
Hey guys we need some cryptonight algos. They have quite a lot now. heavy, lite, V7, lite_v7. thanks
Can we please add tdxminer to the list? It is one of the few most profitable LINUX ONLY miners… https://github.com/todxx/tdxminer/releases/download/v0.2.2.2/tdxminer-v0.2.2.2.tgz
cpuminer-multi-opencl wildkeccak_old AMD-GPU
Algorithms
✓ wildkeccak Purk [PURK]
hi admin
please add tdxminer to the list, It is one of the few most profitable LINUX ONLY miners… https://github.com/todxx/tdxminer/releases/download/v0.2.2.2/tdxminer-v0.2.2.2.tgz
This is a small list of algorithms and coins Hive can mine. Would it be possible to add an updated list to the website or on a sticky to the forum?
ethash
ETH - Ethereum (10,000mh/s)
ETC - Ethereum Classic
ETP - Metaverse ETP
EXP - Expanse
MUSIC - Musicoin
ELLA - Ellaism
ELE - Elementrem
DAXX - DaxxCoin
blake256r14
DCR - Decred
XQD - Dirac
ELT - Electron
BBTC - BlakeBitcoin
BLC - Blakecoin
PHO - Photon
XVC - vcash
TRUMP - trumpcoin
ERA - blakestar
blake2b
SC - Sia Coin
XRB - Nano
CryptoNightV7
XMR - Monero
LNS - Lines
MZT - Myztic
ELYA - Elya
WOW - wowcoin
GRFT - Graft
ITNS - IntenseCoin
SUP - Superior Coin
ETN - Electroneum
pascal
PASC - Pascal Coin
lbry
LBC - LBRY Credits
blake2s
XVG - Verge
HONEY - honey
TAJ - TajCoin
BLAS - BlakeStar
PUPA - PupaCoin
keccak
MAX - Maxcoin
SLOTH - Slothcoin
METH - Cryptometh
NXS - NexusNiro
Equihash
ZEC - Zcash
BTG - Bitcoin Gold
ZEC - ZCash
BTCP - Bitcoin Private
KMD - Komodo
ZEN - ZenCash
ZCL - ZClassic
BTCZ - BitcoinZ
HUSH - Hush
ZER - Zero
ZEL - Zelcash
mkxminer | A | Lyra2rev2 |
lyclMiner |A| Lyra2rev2|
these miners can keep up with greens on this algo
and this algo is the most profitable IMO since NIX just launched
Update pls a new version 1.12 of Z-enemy miner!
https://bitcointalk.org/index.php?topic=3378390.0;all
And update Nvidia Drivers!)
https://bitcointalk.org/index.php?topic=4589691.0
WildRig Miner for Wild Keccak algorithm.
There is Linux version.
After finished work under development of custom miner intergration (tdxminer and t-rex) I’m looking for new blood :stuck_out_tongue:
What we gonna do next?
Ive asked this 3 times in this thread already and it just gets ignored every time. Would it be possible to add the Nicehash Excavator miner for people mining on their pools. Many benefits to using it over other miners on their pools. Ranging from great speed on aglos like lyraRev2 and Neoscrypt and ofc 0% dev fees. PLEASE :slight_smile:
Is tdxminer integrated?! which version? I see only -57 for download ? Or its via update only?
With v0.5-62 was introducing new feature “Custom miner”
http://forum.hiveos.farm/discussion/1273/custom-miner-integration
tdxminer was first custom miner package
Can anyone here test how bad my scripts for custom miner integration of WildRig for wild keccak algo? :slight_smile:
here is a package for 0.9.11 beta.
seems they are bad, failed to run on some installations… need to check everything more, this is problematic develop without possibility to test on my own hardware %)
Another request for JCE Miner Cryptonight/forks, now with GPU!:
https://bitcointalk.org/index.php?topic=3281187.0
Right now it seems like it is the fastest miner for CN variants on CPU, so adding it would be great.
Я две недели не могу настроить EWBF на BTCZ, копает, шары видит, все отлично, а на пул шары не приходят вообще, название воркеров видны на пуле, а солей и шаров ноль! И так на разных пулах (кроме супрновы, там вообще ничего не работает, одни режекты), причем на тех же настройках в винде все копает отлично и шары на пул прилетают!
топик вообще-то не об этом
  "name": "BitcoinZ",
  "props": {
    "ewbf": {
      "algo": "144_5",
      "fork": "zhash",
      "zpass": "x",
      "zport": "2020",
      "zserver": "btcz.2miners.com",
      "ztemplate": "%ZWAL%.%WORKER_NAME%",
      "user_config": "pers BitcoinZ"
    "zwal": "t1Va3HHkb1iJmPnFYLvnXY6HYqVmKLVvz8a"
Good day, can you please add
CryptoDredge. https://bitcointalk.org/index.php?topic=4129696.0
They have just added support for linux.
Algos supported
Allium
Lyra2REv2
Lyra2z
NeoScrypt
PHI1612
Phi2
And its pretty fast, especially compared to some of the miners in hive atm
Thank you
+1 It must be very useful. Please!
Добавьте новый майнер BitTube Miner 1.1.5 (GPU AMD) для монеты TUBE.
Алгоритм - CryptoNightIPBC-Lite.
Ссылка на майнер - https://github.com/ipbc-dev/bittube-miner/releases.
Ссылка на майнер для NVIDIA - https://github.com/ipbc-dev/bittube-miner/releases/tag/1.1.3
-Причина: нет алгоритма на HIVE OS, профитный алгоритм
