Прошу добавить:
T-Rex miner fork ccminer 2.2.5 (tpruvot)
T-Rex miner for modern Nvidia GPUs - Pascal & Maxwell generations
Supported algorithms: Lyra2z, Tribus, Phi1612. Linux version only.
This is a beta version so many features are missing or may not work properly. New algorithms/improvements are on their way.
Supported GPU architecture: Pascal (10xx series) and Maxwell
Performance
Lyra2z:
1070 (Core +160, Mem -500): ~2300 Kh/s
1070 Ti (Core +210, Mem -600): ~2900-3000 Kh/s
1080 Ti: 4200 Kh/s
Tribus:
1070 (Core +190, Mem 0):
PL 150W - 77 Mh/s
PL 130W - 74 Mh/s
PL 180W - 101 Mh/s
PL 150W - 95 Mh/s
1080 Ti: ?
Phi1612:
1070 (Core +170, Mem -500):
PL 130W - 23 Mh/s
PL 180W - 31.5 Mh/s
PL 150W - 29.8 Mh/s
I tested on lyra2z:
1080ti ~ 4390
1070ti ~ 3000
1070 ~ 2350
Amazing miner!
https://bitcointalk.org/index.php?topic=4432704.0
Will a PHI2 miner be added for LUX COre v5?
ccminer 2.2.6 from tpruvot already added and supported phi2
Hello ! would you be able to add Miner TDXminer-v0.2.2.2 to AMD? link:
to enable the work of other currencies with lyra2z algorithm
thank you
[quote=“cya;5007”]EWBF update for Equihash mining changes.
Solver for equihash 200,9 has been deleted.
Solvers for Equihash 192,7 and 144,5 has been added
https://bitcointalk.org/index.php?topic=4466962.0
[/quote]
Please update EWBF, this would enable mining of BTCz without the need of the zhasher miner stated above.
Upvote for T-Rex miner above
t-rex is currently a little unstable and offers no API. I’m currently using it with 1070 TI’s however it just doesnt want to work with my 1070 MSI rig… i saw in the bitcointalk forum that others were also experiencing the same issue
Когда планируете поддержку equihash 144,5?
auuuuu
144.5???
Yes massive miners updates are planned this week
очень хорошо что вы ответили, но что касается смены алгоритмов вы либо должны работать на опережение, либо делать срочные хот фиксы майнеров а не по неделям ждать. Хорошая работа у вас и продукт - но вот эта ситуация очень ставит под вопрос целесообразность его использования.
144.5 ???
Работать на опережение это как??? Разрабатывать майнеры самому быстрее разработчиков??? Пишите эгоистичный бред. Аналогов у этого проекта вообще нет. В других подобных проектах на линуксе вообще по пол года ничего не добавляется и не редактируется, и ими можно майнить только эфир по сути. Единственный конкурент - это найсхэш майнер легаси на винде. Но и там до сих пор нет 144,5 алго. Можете сравнить для интереса, кто добавит 144,5 быстрее - найсхэш или хайв. Я ставлю на хайв. Так найсхэш это целая многопрофильная компания с большой командой, и даже они добавляют/обновляют майнеры только раз в месяц и только те которые считают нужными. А в хайве работают над этими наверное 1-3 человека, раз в 2 недели добавляют все что вы захочете, и вы еще и недовольны… Хотите все и сразу - дуйте на винду, качайте, устанавливайте все сами.
в репозитории ewbf новый добавлен, сегодня скорее всего будет добавлен и новый bminer 9.0.0 (посмотрим ченжлог и опыт тех кто уже попробовал )))) )
выйдет с обновлением
можно ли как то добавить watchdog на bminer 9.0.0 на Mh/s сейчас только Sol/s ?
Any bytom miners available in hive?
For bytom, if you dont want stats, just extract the miner package, adjust LD_LIBRARY_PATH, modify wallet adress and start if from console.
Заявка на добавление майнера:
sgminer
AMD
trubus
BZLcoin
http://site.bzlcoin.org/ https://bitcointalk.org/index.php?topic=2326146.0
Опишу проблему - у меня гибридная ферма NVIDIA-1070/AMD-580
NVIDIA спокойно работает майнером СС miner алгоритм tribus - Denarius, а вот запустить на SG miner AMD не выходит те-же настройки кошелька и майнера пул BSOD stratum+tcp://eu.bsod.pw:2019 различие только в названия Hash algoritm на CC miner tribus - Denarius, на AMD SG miner просто tribus
From JSON
  "name": "BZLcoin",
  "email": "[email protected]",
  "props": {
    "dwal": "BMnGgogAGJhxih1W7dNAgcyHEuaZzxxLJj",
    "ccminer": {
      "ccurl": "stratum+tcp://eu.bsod.pw:2019",
      "ccalgo": "tribus",
      "ccuser": "%DWAL%.%WORKER_NAME%"
    "sgminer-gm": {
      "url": "stratum+tcp://eu.bsod.pw:2019",
      "algo": "tribus",
      "template": "%DWAL%.%WORKER_NAME%"
Возможно устаревший SG miner, прошу Вас помочь мне с этой проблемой.
miner log
[2018-06-24 12:56:54] CL Platform version: OpenCL 2.0 AMD-APP (2482.3)
[2018-06-24 12:56:54] Platform devices: 2
[2018-06-24 12:56:54]   0Ellesmere
[2018-06-24 12:56:54]   1Ellesmere
[2018-06-24 12:56:54] No login credentials supplied for eu.bsod.pwe[?1049le[?1le>
sgminer exited, waiting to cooldown a bit
Fork version:
[2018-06-24 12:56:57] Log date is now 2018-06-24
[2018-06-24 12:56:57] Algorithm tribus not found, using ckolivas.
[2018-06-24 12:56:57] Set default algorithm to ckolivas
iner 5.5.6-gm
[2018-06-24 12:56:57] * using Jansson 2.7iner 5.5.6-gm
[2018-06-24 12:56:57] Loaded configuration file sgminer.conf
[2018-06-24 12:56:57] CL Platform vendor: Advanced Micro Devices, Inc.
[2018-06-24 12:56:57] CL Platform name: AMD Accelerated Parallel Processing
[2018-06-24 12:56:57] CL Platform version: OpenCL 2.0 AMD-APP (2482.3)
[2018-06-24 12:56:57] Platform devices: 2
[2018-06-24 12:56:57]   0Ellesmere
[2018-06-24 12:56:57]   1Ellesmere
[2018-06-24 12:56:57] No login credentials supplied for eu.bsod.pwe[?1049le[?1le>
Fork version:
[2018-06-24 12:57:00] Log date is now 2018-06-24
[2018-06-24 12:57:00] Algorithm tribus not found, using ckolivas.
[2018-06-24 12:57:00] Set default algorithm to ckolivas
iner 5.5.6-gm
[2018-06-24 12:57:00] * using Jansson 2.7iner 5.5.6-gm
[2018-06-24 12:57:00] Loaded configuration file sgminer.conf
[2018-06-24 12:57:00] CL Platform vendor: Advanced Micro Devices, Inc.
[2018-06-24 12:57:00] CL Platform name: AMD Accelerated Parallel Processing
[2018-06-24 12:57:00] CL Platform version: OpenCL 2.0 AMD-APP (2482.3)
[2018-06-24 12:57:00] Platform devices: 2
[2018-06-24 12:57:00]   0Ellesmere
[2018-06-24 12:57:00]   1Ellesmere
[2018-06-24 12:57:00] No login credentials supplied for eu.bsod.pwe[?1049le[?1le>
Fork version:
[12:57:04] Algorithm tribus not found, using ckolivas.
[12:57:04] Set default algorithm to ckolivas
e[4le[He[J[2018-06-24 12:57:04] Log date is now 2018-06-24
[2018-06-24 12:57:04] Started sgminer 5.5.6-gm
[2018-06-24 12:57:04] * using Jansson 2.7e[HeM[2018-06-24 12:57:04] Log date is now 2018-06-24
[2018-06-24 12:57:04] Loaded configuration file sgminer.conf
[2018-06-24 12:57:04] CL Platform vendor: Advanced Micro Devices, Inc.
[2018-06-24 12:57:04] CL Platform name: AMD Accelerated Parallel Processing
[2018-06-24 12:57:04] CL Platform version: OpenCL 2.0 AMD-APP (2482.3)
[2018-06-24 12:57:04] Platform devices: 2
[2018-06-24 12:57:04]   0Ellesmere
[2018-06-24 12:57:04]   1Ellesmere
[2018-06-24 12:57:04] No login credentials supplied for eu.bsod.pwe[?1049le[?1le>
Fork version:
[2018-06-24 12:57:07] Log date is now 2018-06-24
[2018-06-24 12:57:07] Algorithm tribus not found, using ckolivas.
[2018-06-24 12:57:07] Set default algorithm to ckolivas
iner 5.5.6-gm
[2018-06-24 12:57:07] * using Jansson 2.7iner 5.5.6-gm
[2018-06-24 12:57:07] Loaded configuration file sgminer.conf
[2018-06-24 12:57:07] CL Platform vendor: Advanced Micro Devices, Inc.
[2018-06-24 12:57:07] CL Platform name: AMD Accelerated Parallel Processing
[2018-06-24 12:57:07] CL Platform version: OpenCL 2.0 AMD-APP (2482.3)
[2018-06-24 12:57:07] Platform devices: 2
[2018-06-24 12:57:07]   0Ellesmere
[2018-06-24 12:57:07]   1Ellesmere
[2018-06-24 12:57:07] No login credentials supplied for eu.bsod.pwe[?1049le[?1le>
miner config
=== /hive/sgminer/sgminer.conf =================================================
  "temp-target": "68",
  "temp-cutoff": "80",
  "temp-overheat": "82",
  "auto-fan": true,
  "log-file": "/var/log/miner/sgminer/sgminer.log",
  "log-show-date": true,
  "text-only": false,
  "verbose": true,
  "debug": false,
  "per-device-stats": true,
  "log": "15",
  "api-listen": true,
  "api-port": 4028,
  "pools": [
      "user": "BMnGgogAGJhxih1W7dNAgcyHEuaZzxxLJj.RIG_GTX1070",
  "algorithm": "tribus"
Please update ccminer to 2.3 which is required for LUX
