Repurposing former mining rigs for remote gaming — practical limitations?
Hi everyone,
I’m interested in the practical hardware changes involved, especially with RTX 30-series or newer cards:
  • Did you need to replace the mining motherboard or move away from PCIe x1 risers?
  • How much did the CPU, RAM and SSD need upgrading?
  • Did you build separate PCs from the GPUs, or find a practical way to use several cards in one system?
  • What problems did you encounter with drivers, cooling or streaming latency?
I’m mainly looking for firsthand experiences: what worked, what needed replacing, and whether the conversion was worth the effort compared with selling the equipment.
This would all depend greatly on the hardware in question.
That being said, if the cpu is half decent like and i5 or so and you have a minimum of 16 gigs of ram, a nvme drive and the gpu’s sit in a full length slot ( my mining rig has 8 full length pcie slots ) then i imagine transitioning to being a gaming rig would be a breeze. If you have short slots which i think are just 1 pcie lane then your probably in for a hard time. Generally though if your setup can cool itself for mining its probably going to handle gaming just fine.
