I had the same problem and did the same solution,
Just add a suffix on worker in miner config
No matter the name of suffix, exemple my1card my2ndcard, etc…
it works well
But I don’t know if my mining money is lost
Can you guys help me with this problem. I’m always not getting the right amount of hashrate
It’s almost -%30 less than it should be
You are going to need provide a bit more information and the mobile app is not the easiest provide troubleshooting information. It is handy for quick monitoring.
Funcionou perfeitamente pra mim, obrigado!!
Is the goal here to name EACH flight sheet for each miner (rig)? So, ONE flight sheet per rig? Will using the same flight sheet for multiple rigs cause the reporting problem? So, with 5 rigs, each with 3-5 GPUs in them, I should have 5 flight sheets, one for EACH rig? Thanks in advance
This topic was automatically closed 185 days after the last reply. New replies are no longer allowed.
