Raven - Total speed: 1.118 MH/s, Total shares: 0 Rejected: 0 (after 6 hours)
I have set up HiveOS on my rig I previously used with a different system without problems to mine RVN. All looks good on my end, hashrate is as expected, but the pool will not accept any shares. Zero, nada. In 20 hours of mining I had only 2 shares accepted. Nothing is rejected neither. What is going on?
Network is fine, I get 30 ms ping from the pool. I am using nanominer, same miner I used before. I can see my rig on the web interface and it shows correct hashrate and of course zero calculate hashrate.
here ar the config file and miner log:
MINERS HIVE CONFIG
#Selected miners
MINER=nanominer
MINER2=
#Rig timezone
TIMEZONE=“US/Eastern”
#Watchdog
WD_ENABLED=1
WD_MINER=3
WD_REBOOT=5
WD_CHECK_GPU=0
WD_MAX_LA=
WD_ASR=
WD_POWER_ENABLED=0
WD_POWER_MIN=150
WD_POWER_MAX=
WD_POWER_ACTION=reboot
WD_CHECK_CONN=1
WD_SHARE_TIME=
WD_MINHASHES=’{}’
WD_MINHASHES_ALGO=’{}’
WD_TYPE=‘miner’
#Hive Shell server host
HSSH_SRV=“shell.hiveos.farm”
#Options
SHELLINABOX_ENABLE=1
SSH_ENABLE=1
SSH_PASSWORD_ENABLE=1
2023-Nov-27 19:01:58: New job from rvn.hiveon.com:8888
Raven - Total speed: 1.118 MH/s, Total shares: 0 Rejected: 0, Time: 11:30
Raven: GPU 0 177.671 kH/s, GPU 1 187.424 kH/s, GPU 2 188.060 kH/s, GPU 3 188.262 kH/s, GPU 4 188.211 kH/s, GPU 5 188.290 kH/s
Raven last 10 min - GPU 0: 177.657 kH/s, GPU 1: 187.388 kH/s, GPU 2: 187.256 kH/s, GPU 3: 187.924 kH/s, GPU 4: 188.252 kH/s, GPU 5: 187.948 kH/s. Total: 1.116 MH/s.
Never mind. I have figured it out. I did not realize that since I last tried RVN the DAG file had grown, it is now beyond my reach. Should have checked it first.
This topic was automatically closed 185 days after the last reply. New replies are no longer allowed.
