Hello everyone,
I am new into AMD Cards for mining. I usually use Nvidia. Now I got my hands on a Vii Pro. I have already the normal Vii and it works perfectly but the Pro is not able to respond to the overclock settings I adjust inside Hive OS. The card starts mining in KawPow and easily reaches the 42Mhs but unfortunately due to one fan the card overheats after second to 90 degrees. Therefore I really need to adjust the setting but yeah everything I put in is not applying. Nothing happens. Only the fan speed is adjustable.
What should I do? I tried to find some solutions in the Internet but everything I got is for the Vii not for the Pro. Does anyone experienced the same issue and know how to deal with that?
Thanks in advance
Regards
