I hope that my post will be accepted because i’ve serach and i haven’t found the same item in the different topic.I’ve recently discover and started mining with my RIG ( 6 GPU RX 580 4GO ), and i post this message because i don’t understand why my Hasrate is also low. 95MH on Ethereum.Could you help me to solve my problem.Thanks for your comprehension.Best Regards
hi,
Have you discover the problem for the Low Hasrate ?
I have the same Problem with [Radeon RX 580 4096 MB · Sapphire Elpida EDW4032BABG 113-1E3660EU-O55]
Right now aren’t minining and not showing any Hasrate. What Cofig are you using
Need help with this issue.
Best Regards
I have exactly the same cards and same issue only getting 80mh/s
hi, @Stephdu83 !
Did you find a solution to your problem?
I’m in the same boat with you.
Here’s a printrscreen of mine and I don’t know what else can be done
