I need BIOS for 5600 xt gigabyte.
I have 39.34mh.
I have 39.34mh.
Please match your Sub Vendor and Sub ID before you flash the GPU. This only works with GPU with Micron memory.
I’m using Sapphire Pulse RX5600XT dual bios version and bios modded from Red Panda Mining discord channel, but the power consumption is very high. Is this bios for Sapphire or MSI?
Did the bios ever get shared? I’d love to try it out as well.
So I can put this BiOS on any 5600 XT with Micron?
I will try later today.
What about cards with Samsung?
I won’t flash any card with Samsung BIOS, too much hassle, not worth the time.
Can you share a link to the bios for Micron. I have flashed my Samsung with modified Bios and they are running very efficiently. I have a Micron that seems very problematic and does not like the Bios I am using,
Hello!! I have a 5600 xt with samsung, but I can´t find how modified Bios.
The OC that it has now, isnt very effciently. It crash all the time (error " GPU 2: detected DEAD (0a:00.0), will execute restart script watchdog.sh")
How did you modify the bios?
thanks for helping!!
Hello champion, can you send me your bios to [email protected]
I will be very grateful to you, greetings
hi, did you find out?
please share the bios mod for micron memory
hello i have the same card i need help can you share your bios with me
Same here, looking for a good modded bios for Sapphire 5600XT BE, Micron 113-D1891011-O05. Email [email protected]. Thanks!
