Hi there,
I’m seting up two 6 GPU rigs with a Z390-A Pro motherboards and Radeon RX 470 4096 MB · Sapphire GPUs.
I can get it running fine with 4 GPUs but when I add a 5th one after a few minutes I get an “Autofan: GPU temperature 511 is unreal, driver error”.
I have been trying to troubleshoot it but unfortunatly I still didn’t come to a solution.
- I tried to add the GPUs one by one to check, and to try them on difertent slots and all I can conclude is that when I add a 5th one, i get that error.
- I checked the drivers and I supose they are the latest ones: OpenCL 20.40.
- Hiveos is upgraded to the latest version.
- On the BIOS I have set up PEG0 to Gen2, Latency Timer to 96 and enabled the Above 4GB memory enabled.
I would be gratefull if anyone have any hints on how to solve it.
Thanks,
David
