Has anyone gotten a decent setup or bios to adapt? Thanks
I just got one in today. Any luck or update?
I have not succeeded
What happens when you open the BIOS in RedBIOSeditor?
It says not supported and won’t do anything.
…I am getting stable finally with Polaris Bios Editor @ ~22mh/s, but my stales are 50% plus. Any ideas?
Which “clkernel” setting are you using?
Using “clkernel 0” with the Polaris cards will trigger a LOT of false stales.
You should specifically set “clkernel 1” (hopefully it works with that card) to get a better hashrate and a normal amount of stales.
some news? Does anyone have them working?
Any news on this. I too can’t get my WX 7100 to mine in HiveOS. But oddly enough my Pro Duo Polaris show up as 2 different WX 7100 in Hive OS and mine just fine at 30mh… WTH? Any ideas?
The Radeon Pro Duo is a dual GPU card (hence the Duo in the name). It is two WX 7100s with 16GB of VRAM each on a single PCIE card. I would be worried if it didn’t present as two WX 7100 cards. But it sounds like everything is working normally and correctly. Congrats on finding out you had one more GPU than you thought you did
