I’am using 6x R9 390’s on my rig.
The problem is that some of the cards are running too high, and the fan speed is too low. I set this to 100%, but that doesn’t work. I guess fans keep running on AUTO.
I also tested this at home with my RX 480. That fan was set to 100%.
Als my H110 BTC+ motherboard won’t always boot with internet connection. 2/5 times it boots without activating the network controller. Is there a way, to keep rebooten untill it makes connection? Or another driver that always makes connection?
