Question on remote rig location
Planning on relocating my rig to my office location since I have a lab there with free (to me) electricity… I have a private internet connection there for my use but am wondering if there are any special ports I need to setup in order for me to remotely manage and use shell in a box from my home or elsewhere…
I would login to dashboard and manage from there. So far it has worked great, but I am on the same network here. That would change after relocating.
Shellinabox is for local network only, you can use hive shell from any network instead.
Thanks. Didn’t know about it, but I found it and checked it out.
Now to find some more gpus without a 2nd mortgage lol!
It works the same pretty much. And good luck, you’ll need it haha.
