Problems with Rig 7x1660ti
Hello forum! Good morning, how are you?
I’m having problems with one of my rigs… It has 7 1660ti and 1 1660s. The following happens: using the same OC settings there are two 1660ti that performs much less. Any suggestions?
tune each card individually and see what youre able to get. if one is still lower, try swapping cards around and see if the low performance follows the card or the riser/slot.
I changed the risers on the boards with less mhs and nothing. I also tried another power supply but nothing. Any idea ?
