hello, when starting the rig it always has problems connecting to the pool, it takes 8 to 12 minutes to finally connect. This happens every time you try to connect, and it is always the same 10 or 12 minutes and connect.
!if you had problems with SSL/TLS connection then try no used them
Is there any security risk with HTTP connection to the pool?
As a general security practice I prefer all my internet communications to be secured over SSL.
Why the pool will not connect to SSL?
Do we need to update the certificates with HiveOS?
Thanks.
AlleyCat
i discover the problem or better the solution: The port 4444 is blocked and in the advanced i changed for 14444 and fixed
These ports are for non ssl connections.
This topic was automatically closed 185 days after the last reply. New replies are no longer allowed.
