Problems after lost Internet connection
Hey everyone,
I am using HiveOS for my mining rig. My internet is not very stable at the moment. An Ethernet cable goes from my router into a switch, from which three Etheret cables go into three smaller rigs.
Problem: When I loose my internet connection. The rigs go offline. When my internet is back, the rigs do not reconnect automatically. If have to manually turn off the hardware and then start it again. Is it the same for you guys, or do your rigs continue mining when your internet returns?
Also, if I am the only one with this problem, does someone happen to know if the problem is my router or my switch? (Switch is Netgear GS108 8-Port 10/100/1000 Gigabit)
I am also facing a same issue.
