Hi
My XFX RX6800XT Power Consumption Indicates 100 to 103 watts but Actually every GPU 200 watts Indicates by wattmeter
Why?
the way amd cards report wattage is based on the vrm voltages, when theyre undervolted/overclocked these calculations are far from accurate.
try core: 1235, 635v
and mem: 1068, 710mv, 1220mv
soc 1201mhz, 800mv
for me hiveos shows 79w @ 63.2mh/s. ~130w at the wall
Thank You My Friend
What’s you Miner? gminer or teamredminer …?
i use phoenixminer, gminer is ok also, but very sensitive to soc mv. teamredminer doesnt work for me at all, the hashrates go all over the place.
Do Will damage the gpus in the long time?
Hi Dear esoooo
I overclocked these parameters and two gpus are 63.1 MH/S but one of them 58 MH/S!
Do You Know what’s the problem?
Voltage it too low in one or more of the areas in my experience.
try setting the SoC Mhz, 876. for me if hashrate fluctuates is bcos the soc is changing mhz quite frequently
