Problem with Transferring Hive OS from a flash-drive to SDD/HDD using Hive OS itself
Hi
me have a problem with Transferring Hive OS from a flash-drive to SDD/HDD using Hive OS itself.
my rig work normally with flash drive but when transferring hive os from flash-drive to ssd
rig dont mine and have error (below pic)
my usb drive 32 gb and my ssd 128 gb
after transfer me shutdown rig and unplug the flash drive.
system booted and hive os run normally but dont mine and show error
me use this help link for trasfer flash drive to ssd.
did you try running apt-get update as it mentioned? also you can try hive-replace
yes
but not worked !
try running mv /var/lib/dpkg/status-old /var/lib/dpkg/status
not worked !
me google it and find this
sudo rm /var/lib/dpkg/status
sudo cp /var/backups/dpkg.status.0 /var/lib/dpkg/status
sudo apt-get update
after this solved my problem
thank you
