Problem with too much rejected ratio after update miner
Hello miners :wave: yesterday i saw problem in my miner with too much rejected shares (as you can see in picture below). Anyone had that problem? Before i have efficiency like a 99.90% but now ~90%. Best regards.
what cards/clocks are you running?
switch to locked core clocks on the 3060tis, 1500mhz in place of the -500s and remove the power limits and then reboot.
Overclocking is not a problem here, the cards have been mining like this overclock for a few months and suddenly have a lot of rejected ratio.
try what i said and see if it fixes your issue
I tried it and unfortunately it doesn’t work, one of the 3060 have 6 invalid shared in 5 min :confused:
Might be worth trying the problem card on its own. Reduce memory clocks until there’s no invalids or rejects
