We have a problem with this rig, I’m sending an error in the screen that the rig is reporting to us. This error occurs regularly usually after 3 to 4 days of operation.
i would start with updating everything, fresh install hive install to get the latest kernel, drivers etc. upgrade hive, make sure miner is on latest, latest bios etc. if you still have issues you can try swapping them around and see if the issue follows the card or the riser. if it follows the card continue reducing clocks until it stops getting rejects/invalids.
