Rig was running fine, then shut down my rig to do a maintenance cleaning since it’s been gathering a lot of dust and temp is around 2 to 3 degrees higher than before. after cleaning each GTX1660S and installing it back where they where installed, then booted up the system it’s now give me error on all 5 of my 1660S…[drm:nv_drm_load [nvidia_drm]]GPU ID 0x000000200 Failed to allocate NvKmsKapiDevice
no matter how I re-installed it on the riser, changed the USB cables, nothing worked! help!
Test each one on its own, see if you can narrow down which card is causing the issues. (You may be able to match the pcie bus id location in the error to the gpu as well)
