Hi everbody
I have been using a new antminer s19 86 t a for acouple of days fine , but then red light and it stopped mining , i have tried updating and cleaning but nothing. This is my log could anybody give me any advice?
2015-01-01 00:00:15 Open miner sn file /config/sn error
2015-01-01 00:00:15 Miner compile time: Mon Dec 26 17:10:01 CST 2022 type: Antminer BHB42XXX sn :
2015-01-01 00:00:16 This is fix-freq version
2015-01-01 00:00:16 Miner compile time: Mon Dec 26 17:10:01 CST 2022 type: Antminer BHB42XXX
2015-01-01 00:00:16 commit version: f2ab6bc 2022-12-26 17:08:34, build by: jenkins 2022-12-26 17:22:17
2015-01-01 00:00:16 opt_multi_version = 1
2015-01-01 00:00:16 opt_bitmain_ab = 1
2015-01-01 00:00:16 mid_auto_gen = 1
2015-01-01 00:00:16 opt_bitmain_work_mode = 0
2015-01-01 00:00:16 port 439 already exported
2015-01-01 00:00:16 port 454 already exported
2015-01-01 00:00:16 port 440 already exported
2015-01-01 00:00:16 port 455 already exported
2015-01-01 00:00:16 port 441 already exported
2015-01-01 00:00:16 port 456 already exported
2015-01-01 00:00:16 port 438 already exported
2015-01-01 00:00:16 port 453 already exported
2015-01-01 00:00:16 port 446 already exported
2015-01-01 00:00:16 port 445 already exported
2015-01-01 00:00:16 Note: front fan is power on!
2015-01-01 00:00:16 Note: rear fan is power on!
2015-01-01 00:00:16 start the http log.
2015-01-01 00:00:16 httpListenThread start ret=0
2015-01-01 00:00:16 start listen on 6060 …
2015-01-01 00:00:16 bad chain id = 3
2015-01-01 00:00:19 bad chain id = 3
2015-01-01 00:00:21 ==========================capability start==========================
2015-01-01 00:00:21 board num = 3
2015-01-01 00:00:21 board id = 0, chain num = 1
2015-01-01 00:00:21 chain id = 0
2015-01-01 00:00:21 board id = 1, chain num = 1
2015-01-01 00:00:21 chain id = 1
2015-01-01 00:00:21 board id = 2, chain num = 1
2015-01-01 00:00:21 chain id = 2
2015-01-01 00:00:21 ==========================capability end============================
2015-01-01 00:00:21 chain num = 3
2015-01-01 00:00:21 skip loading levels for now
2015-01-01 00:00:25 load chain 0 eeprom data
2015-01-01 00:00:28 load chain 1 eeprom data
2015-01-01 00:00:31 load chain 2 eeprom data
2015-01-01 00:00:31 miner type: Antminer S19
2015-01-01 00:00:31 multi machine mode
2015-01-01 00:00:31 load machine BHB42831 conf
2015-01-01 00:00:31 machine : BHB42831
2015-01-01 00:00:31 chain_num 4, chain_domain_num 44, chain_asic_num 88, domain_asic_num 2
2015-01-01 00:00:31 abandon mix board!
2015-01-01 00:00:31 fan_eft : 0 fan_pwm : 95
2015-01-01 00:00:31 create thread get_nonce_and_register_thread
2015-01-01 00:00:31 fixed working voltage = 1580
2015-01-01 00:00:31 fixed frequency is 645
2015-01-01 00:00:31 Chain [0] PCB Version: 0x0100
2015-01-01 00:00:31 Chain [0] BOM Version: 0x0010
2015-01-01 00:00:31 Chain [1] PCB Version: 0x0100
2015-01-01 00:00:31 Chain [1] BOM Version: 0x0010
2015-01-01 00:00:31 Chain [2] PCB Version: 0x0100
2015-01-01 00:00:31 Chain [2] BOM Version: 0x0010
2015-01-01 00:00:31 bad chain id = 3
2015-01-01 00:00:31 Fan check passed.
2015-01-01 00:00:31 uart_trans addr:0xf6fc1000.
2015-01-01 00:00:31 max sensor num = 4
2015-01-01 00:00:31 STATUS_INITED: soc init done!
2015-01-01 00:00:31 temperature_monitor_thread start…
2023-11-30 13:41:31 start to init…
2023-11-30 13:41:31 i2c_sim_init start
2023-11-30 13:41:31 init gpio477
2023-11-30 13:41:31 init gpio476
2023-11-30 13:41:31 i2c_sim_init end
2023-11-30 13:41:33 power open power_version = 0x78
2023-11-30 13:41:36 power is not Calibrated
2023-11-30 13:41:36 warning:power is not calibration.
2023-11-30 13:41:37 power type version: 0x0078
2023-11-30 13:41:41 disable power watchdog: 0x0000
2023-11-30 13:41:42 Initializing the power, please wait, this may take up to 2 minutes…
2023-11-30 13:42:13 Slept 30 seconds, diff = 0.
2023-11-30 13:42:17 set_voltage_by_steps to 1700.
2023-11-30 13:42:27 start up min temp by 75a = 23
2023-11-30 13:42:30 Chain[0]: find 82 asic, times 0
2023-11-30 13:42:32 Chain[0]: find 82 asic, times 1
2023-11-30 13:42:34 Chain[0]: find 81 asic, times 2
2023-11-30 13:42:34 Chain 0 only find 81 asic, will power off hash board 0
2023-11-30 13:42:36 Chain[1]: find 88 asic, times 0
2023-11-30 13:42:38 Chain[2]: find 88 asic, times 0
2023-11-30 13:42:38 ERROR_SOC_INIT: soc init failed!
2023-11-30 13:42:38 stop_mining: soc init failed!
2023-11-30 13:42:38 uninit_temp_info
2023-11-30 13:42:38 do not read temp anymore…
2023-11-30 13:42:38 cancel thread
2023-11-30 13:42:38 power off hashboard
2023-11-30 13:42:38 temp monitor thread exit
2023-11-30 13:42:40 Version num 65536
2023-11-30 13:42:40 Mask num 0x1fffe000
2023-11-30 13:42:40 opt_multi_version = 65536, interval timeout = 2397190
2023-11-30 13:42:40 freq = 645, percent = 90, hcn = 4064, timeout = 2397190
