Problem with GPU
Hello I have the following problem, after starting the OS gives the cards in red on the site. I’m asking for help.https://forum.hiveos.farm/uploads/editor/m2/g1856xwiaadk.png
This could be many things- power supply too weak, bad motherboard, etc. When you type “miner” from the command line, does the mining software show 4 GPUs?
check 4g decoding status in bios!
Hello I’ve solved the problem. Incorrectly configured portfolios, as a result of which a miner can not start correctly
What portfolios? Having the same problem.
