Problem with dpkg: error
Im having a problem setting up my miner on hive OS. in hive os its reading " dpkg: error: parsing file ‘/var/lib/dpkg/updates/0024’ near line 0:
newline in field name ‘#padding’.
in hive os it says to run the command ‘dpkg --configure -a’ to correct the problem. i ran that command a few times and still hasn’t fixed it. how to i go about fixing this error problem? i’m at a total loss and my miners aren’t even running because of this error.
Sounds like you have some corrupt files, probably best to reflash your drive with the latest stable/beta image.
You can try running hive-replace -s -y from shell, but you may need to get a new drive if that or reflashing from a pc doesnt work.
