Problem with Aorus 5700XT
Hi, I installed 4x brand new Aorus 5700 XT cards yesterday, no BIOS modding and started the rig, it was stable for 6 hours. Then it wrote error “GPU0 found dead” and rebooted. After the reboot, only 3 cards are working. The last one cannot be seen by HiveOS, but also the fans are not spinning and the LED lights on the card are off.
I changed the riser, checked all the cables. Everything seems to be fine. Did the card died? Is there any help how to try to make it work again or how to check if the card is really dead. I tried to google or search the forum. Thanks.
