Problem with a USB WIFI card
Hi I have a problem with a USB WIFI card. The card is model Ralink Tech MT7601U Wireless Adapter
The card is easily recognized by the operating system HiveOS, but I have large packet losses and high times to my internal network.
Ping statistics for 192.168.0.113:
Packets: Sent = 166, Received = 122, Lost = 44 (26% loss),
Approximate round trip times in milli-seconds:
Minimum = 3ms, Maximum = 3925ms, Average = 1246ms
The distance from the RIG to my router is about 1 meter. I put the card on a computer with Windows 10 and there is no such problem.
Can you help me?
Wifi and mining = problems. You will get more stale shares (which is bad). If you really want to use usb wifi card with your minig rig, use usb extender cable (example link below) and position the wifi card (antenna) as far away as you can from the rig. GPUs are making interference with wifi signal. Your Ralink wifi signal is interrupted by working GPUs. Use at least 1m usb cable. Your router shoult also be at least 1m away from the gpus
The best what you can do is to use rj45 lan cable if you can, to connect your rig to the router
https://www.aliexpress.com/item/4000971868033.html?spm=a2g0o.productlist.0.0.a09b39c5YjPyQY&algo_pvid=5f248238-cb87-429a-bc8e-c5b09c8e56fb&algo_expid=5f248238-cb87-429a-bc8e-c5b09c8e56fb-0&btsid=2100bddb16057313577923467e261c&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
