Hello, so as you can see in picture one zotac is working good and the other only getting 33 mhs, maybe someone know how to fix this? Thanks!
What miner are your using? Also, have you checked if your card is thermal throttling?
nvidia-smi -q | egrep "Thermal Slowdown"
Hey in new to mining, so didint check. What this code does? And where to type it, thanks!
Try 900-930 core. Then bring mem down if still crashing
Here is my video that shows how to remote into your rig and type into the console. Just type the command in while your rig has been mining for a bit. It will show if any of your nvidia cards are thermal throttling. If they are, that means they are limiting themselves because they are getting to hot.
Hey, this video really helped me. So i yesterday i put my fans to 95% on my zotac and it seems that it fixed the problem, now it gets 60-61 mh/s.
BTW i’m a subscriber now
Glad it helped and thanks!
