Problem with 1050ti on ETH
Sometimes I have a problem that the mineral consumes a very large amount of memory and stops practically responding, and the mining falls by half.
This happens between 2h and 60h miner’s work
What could be the reason?
You are correctly identified part of problem.
The second half part is searching source.
Often this is:
  • bad riser
  • core or memory errors
  • bad power
  • something else …
This is not the answer that I would like to hear: D Well, I will be looking for a generation in equipment, it may still be wrong.
Thanks for the tip.
