I startet last Monday with my first rig with Hive OS. These are my components:
MSI B450 GAMING PLUS MAX 7B86-016R
AMD RYZEN 3 2200G YD2200C5FBBOX
CORSAIR SERIES RM1000X CP-9020094-EU
8GB CORSAIR DDR4-2133 CMV8GX4M1A2133C15
WD GREEN SSD 3D NAND WDS120G2G0A 120GB
2 x GIGABYTE GeForce RTX 2060 OC 6G 2.0
1 x Zotac GeForce RTX 3070 Twin Edge OC White Edition 8GB
3 x KOLINK PCI-E 1x to 16 x Powered Riser
With to 2 cards in any combination the rig is mining stable. But when I put into the 3rd card without any bios configuration, it’s ignored by the mainboard.
For this problem I found already the bio configuration “Above 4G Decoding”. After enabling it, I reboot with 2 cards. > Everything was fine. Then I tried to add the 3rd card, but the rig didn’t came up again. That means it’s starts to boot, but the screen stays black.
I removed all 3 cards and reset the BIOS. > PC works fine. > enabled “Above 4G Decoding” and reboot> PC works fine > added first card and reboot> PC works fine > added 2nd card and reboot> PC works fine > added 3rd card and reboot> PC didn’t come up again
Is there any other BIOS configuration, what I have missed there?
Are the cards not compatible? (I can’t imagine this
Are there any other ideas for a solution?
Thanks for some tips
