Hi there, I am new with Hive Os. Previously I was using another OS with my five XFX RX580 8GB Rig. I was getting about 31,5 MHS per GPU with phoenixminer.
I install HiveOS on a pendrive to try it, I made all the setup process and after that the Rig was giving about 29,5 MHS per GPU wtih phoenix and the same with teamredminer, with the default setup.
So I set the same values I used in my other OS, Core 1200 Mhz 800 mv, Memory 2200 Mhz 900mv thinking I will get the 31,5 MHS again, but the miner continuosly reboots because of stucked GPUs. I tried to lower the parameters but the same happens in phoenix a temredminer. The rig only works if I delete all the overclocking settings.
Doing some research I discovered that when I use the adm-info command in the console it always shows 800mv for the memory independently of the value I set in the overclocking tab of my worker. I also discovered that the memory voltage value follows the value of the core voltage, I mean if I set my core voltage to 825mv, then the memory voltage also shows 825 mv in the console amd-info information, no matter what value I have really set for the memory in the overclocking tab.
May be that the amd-info is only showing a wrong value ? or may be that is really setting the memory voltage to the same value as the core voltage ? then it will be normal that the GPU are getting stucked.
Did any one have a similar problem? or know how to fix it ?
Thank you very much !
