Hi !
I have a small android app i use for monitoring claymore, and i love it.
Under windows, i used the -mpsw parameter for reboot, disable GPU, etc. from this app.
By using HiveOs i had to disable the -mpsw because with a password, HiveOs can’t retrieve the parameters (hashrate). As show on the picture joined.
Do you know it it’s possible to use the -mpasw parameter AND having the hashrate showed in HiveOs ? Where put it ? Wallet or Rig (tuning) ?
Thanks for you help.http://forum.hiveos.farm/uploads/editor/he/dus2nptgrasy.png
