I recently bought a 3070Ti and I don’t have a 2x8pin power cable for that card. I bought a brandless cable but this doesn’t turn on the GPU. I test the card with the original cable and works so I figured out that the cable is bad.
I have two pci-e 1x8pin cables.
Could I power the GPU with these two cables instead of one 2x8pin? This would overheat my card? This setup would put at risk my card?
Thanks in advance.
