I bought 2 supplies in my new rig and they are connected together, but one of the supplies does not turn on its coler, is it normal that it does not turn on its fan?
please see if your rig is running perfectly then watch for some time, still not run the cooler fan then try to test the PSU using a (short socket) normally comes with the PSU or if you know how to test the PSU only using a power cable then short the 2pins to on the PSU.
if the PSU run the cooler then it’s ok if not then have to see more for PSU
