Hi, I have issue with one of my rig, it semply PC with one card 3080 and power suply 600W. I thinq this issue caused by power supply. So its will be very helpful if voltage sensors showin in UI. This would make it possible to see voltage dips in real time under load. I try install lm-sensors, then try use command sensors-detect and then use ‘sensors’ command, but it shows only cpu temp.
sudo sensor-detect command show:
Sorry, no sensors were detected.
Either your system has no sensors, or they are not supported, or
they are connected to an I2C or SMBus adapter that is not
supported. If you find out what chips are on your board.
I thinq its will be good fiture to show sensors information on UI
Or add lm-sensors to distributive
For instance, I’m using corsair hxi psu, but have to jump over to the cli to check the voltages, power usage, or temp for the psu.
