I am using a btc360 pro motherboard, i3, and 8 gb of memory and ssd. All this give arround 230 watts without any gpu. When I connect first gpu, using always maximum watts, like not consider the overclock done on hiveos… In Hive os all overclock of 3 gpus, says 460 watts of the 3 gpus overclock, what should be with in total arround 700-800 watts consider that they are in risers. But I bought 3 measure power for wall, and reading is a total of 1140 watts, stable.
My power supply is a mining power supply of 1800 watts, once I was thinking in add more gpus, but with the actual consume of 1140 watts on wall, I start thinking if is really worth to do it.
I really appreciate and grateful for your help on this.
I already check my biostar motherboard bios, and it’s updated… Just valours of watts consume on Hive os, it doesn’t match on wall measure.
