Power button switch disable
I want to prevent it from working even if I press the power button switch on the pc in the hive boot state. How do I turn off the power switch?
The cat keeps touching me!!
If you search for the same question but add Ubuntu to your question you should get a few different ways of handling it, since it’s just Ubuntu underneath hive.
You can also unplug the physical power button switch on the motherboard (usually at the bottom right, and should be labeled power sw or similar)
Is it impossible to modify the system file other than physically removing the line?
No like i said try some guides for Ubuntu as thats what is underneath hive
