I can’t access port 8001 and timing out when I check with netcat, Miner is trying to access it from outside using public IP.
Can you provide some more info on what your issue is? Which miner/algo, what image youre running, error codes/screenshots etc.
NFO:core.miner:[save_validators] Sync validators >>> {"coro_name": "start", "task_id": 136387657286848, "external_port": 8000, "external_ip": "34.42.10.21"}
INFO:consumers.validator_consumer:Found 1 executors for validator(5D7aRtpmVBKsQRzMA2ioUPL25onJPzBjiFVVt5uPZ3TDsn51)
INFO:consumers.validator_consumer:Validator 5D7aRtpmVBKsQRzMA2ioUPL25onJPzBjiFVVt5uPZ3TDsn51 sent SSH Pubkey.
ERROR:services.executor_service:API request failed to register SSH key. url=http://67.222.112.81:8001/upload_ssh_key
INFO:services.executor_service:Send pubkey register API requests to 1 executors and received results from 0 executors
^ That is the error … i am running a miner called celium… the image is 18.04
