Can someone tell my why is the PNY card so bad at mining?
What should i do so that it preformes as the rest?
Run nvtool --throttle and see what it says, troubleshoot riser, cables and psu.
Unknown error
Can you post a screenshot? Are you sure you’re running the command exactly as typed?
It will most likely happen again: Memory hitting high temp and falling to minimum power mode. Either lower oc (try with -2000 and see) or open the card and change the pads.
gddr6 shouldnt get too hot on a 3070, it runs a lot cooler than 6x. either way the throttle command will show if thats the cause
