care to explain your issue ?
can you just tell me the reason shown here ?
does the card work?
card appears at boot screen
Does the display output work on that card? Have you tested it in other systems to confirm it’s fully working?
output worked. if running on winddown, it will get 1 time for about 10s hastrate to zero then return to error
sounds like a card issue more than a hive issue then if the card fails in windows too
I also think there is a problem with the . remove the thermal paste and look for the problem areas…
