so i have 5 gpu 2 3060, 2 1070Ti and a 1070
AT first i couldnt get the two 3060 to run at same time. on post i would get a fuzzy screen and get no where… as soon as i unplugged and completely disconnected a 3060 it posted and worked fine… i then tried different risers… different usb cables and tested all the pcie slots… problem was the same if i tried to use all 5 cards… as soon i unplugged one of the 1070 and put that power cable into one of the 3060 it posted fine… do you guys think my 850 watt power supply is not sufficient for the 5 cards and is causing that issue? or do you guys think there is something funky going on with trying to use 5 pcie slots at the same time? i have a Z390-P 300 series motherboard … like maybe im only able to use 4 PCI lanes even though it has 6? thanks for your help!
*** MORE INFO - for sure looking like a motherboard issue or restriction… i removed ONLY the pci riser usb to the 5th card and she powered on and posted fine… so i dont think its a power issue… anyone else run into anything similar?
**** FIXED *** in case anyone else runs into this issue here is what i did that fixed it… updated to latest bios… disabled onboard audio and bluetooth and enabled 4g decoding… now i can see all 5 cards in Hive OS… now i wish i could actually mine using the 3060… seems unfair to pay for an entire card and only be able to utilize half its potential… dont think nvidia was right by doing what they did. . anyway hopefully there will be a light at the end of the tunnel for us 3060 GPU miners soon! cmon hive os devs you can do it!
